Can anyone look at my pics and confirm if t480 lid is magnesium?
https://imgur.com/a/je3mIU1 has vids and pics.
Thank you. I tried entering the serial number / MTM on the lenovo website, but it doesn't give the LID MATERIAL info (though it gave other details like CPU, battery, etc).
Re: Can anyone look at my pics and confirm if t480 lid is magnesium?
I'm not sure it can be determined from exterior images. Does the website give the LCD lid (rear cover) FRU for your serial number? I believe the FRU for the magnesium lid is 01AX955.
It's difficult to understand from a photo. In a cool environment, it colder to touch, compared to the other parts of the laptop?
Also the plastic lids have a tackier surface. Overall, it's difficult to understand externally. But if the laptop's working, does it even matter?
I'd tap it with a coin, comparing to something of similar shape and thickness.
Metal probably sounds different than plastic.
Magnesium is a heat conductor, plastic is a heat insulator. Place ice in a plastic bag and put it in a corner of the lid. It's it's magnesium, you should be able to feel the cold in the opposite corner quickly.gulencocuk wrote: ↑Wed Dec 27, 2023 12:13 pmIt's difficult to understand from a photo. In a cool environment, it colder to touch, compared to the other parts of the laptop?
AZ91D alloy, which is the thing they use on Thinkpads, has a thermal conductivity of about 50 W/m·K. ABS plastic, less than 1 W/m·K.
X1C5: 7600U | 16GB | 1TB | FHD
X1C9: 1145G7 | 16GB | 1TB | WUXGA | WWAN
P14s G1 AMD: 4750U | 32GB | 1TB | PG FHD Touch
T14 G2: 1145G7 | 32GB | 1TB | FHD
[X230] Magnesium body repair
by samveen » Sun Apr 14, 2024 11:38 pm » in ThinkPad X230-X280 / X390 Series - 2 Replies
- 322 Views
Last post by samveen
Wed Apr 17, 2024 12:29 am
updating T480 bios without Windows (I use Linux)
by redglow » Fri Nov 03, 2023 3:15 am » in ThinkPad T430-T490 / T530-T590 Series - 25 Replies
- 30909 Views
Last post by redglow
Tue Nov 14, 2023 1:00 pm
- 2 Replies
- 7073 Views
Last post by keithsketchley
Mon Feb 26, 2024 10:14 am
Confused what NVME adapter is compatible with my Lenovo Thinkpad T480
by Cyber Akuma » Sat Dec 30, 2023 7:32 pm » in ThinkPad T430-T490 / T530-T590 Series - 1 Replies
- 2236 Views
Sun Dec 31, 2023 1:17 am
