Youtube on T4x
Re: Youtube on T4x
I found that Youtube (Firefox 64 bit) playback improved on my T500 when I disabled browser hardware acceleration. I think by default it tries to use the GPU but neither GMA 4500 nor Radeon 3650 can decode modern codecs. The CPU on the other hand is powerful enough.
sent from my iPhone
Re: Youtube on T4x
Thinkpad4by3
Re: Youtube on T4x
And the one about that trackpoint names!
Re: Youtube on T4x
im on ATI 9600 64mb ram with chromium installed on linux. it has full hardware acceleration and easily does 720p full screen on youtube in the browser. it even runs 1080p in the browser on YT but isnt as smooth.
check your hardware acceleration using "chrome://gpu" in the address bar.
This is what it looks like
Graphics Feature Status
Canvas: Hardware accelerated
CheckerImaging: Disabled
Flash: Hardware accelerated
Flash Stage3D: Hardware accelerated
Flash Stage3D Baseline profile: Hardware accelerated
Compositing: Hardware accelerated
Multiple Raster Threads: Force enabled
Native GpuMemoryBuffers: Software only. Hardware acceleration disabled
Rasterization: Software only. Hardware acceleration disabled
Video Decode: Hardware accelerated
Video Encode: Hardware accelerated
WebGL: Hardware accelerated
WebGL2: Hardware accelerated
Driver Bug Workarounds
adjust_src_dst_region_for_blitframebuffer
clear_uniforms_before_first_program_use
count_all_in_varyings_packing
decode_encode_srgb_for_generatemipmap
disable_framebuffer_cmaa
disable_post_sub_buffers_for_onscreen_surfaces
disable_software_to_accelerated_canvas_upgrade
dont_remove_invariant_for_fragment_input
force_cube_map_positive_x_allocation
force_int_or_srgb_cube_texture_complete
init_texture_max_anisotropy
regenerate_struct_names
remove_invariant_and_centroid_for_essl3
scalarize_vec_and_mat_constructor_args
Problems Detected
Clear uniforms before first program use on all platforms: 124764, 349137
Applied Workarounds: clear_uniforms_before_first_program_use
Mesa drivers in Linux handle varyings without static use incorrectly: 333885
Applied Workarounds: count_all_in_varyings_packing
Linux AMD drivers incorrectly return initial value of 1 for TEXTURE_MAX_ANISOTROPY: 348237
Applied Workarounds: init_texture_max_anisotropy
Always rewrite vec/mat constructors to be consistent: 398694
Applied Workarounds: scalarize_vec_and_mat_constructor_args
Linux AMD drivers handle struct scopes incorrectly: 403957
Applied Workarounds: regenerate_struct_names
Linux ATI drivers crash on binding incomplete cube map texture to FBO: 518889
Applied Workarounds: force_cube_map_positive_x_allocation
Limited enabling of Chromium GL_INTEL_framebuffer_CMAA: 535198
Applied Workarounds: disable_framebuffer_cmaa
Disable partial swaps on Mesa drivers (detected with GL_VERSION): 339493
Applied Workarounds: disable_post_sub_buffers_for_onscreen_surfaces
Decode and encode before generateMipmap for srgb format textures on os except macosx: 634519
Applied Workarounds: decode_encode_srgb_for_generatemipmap
adjust src/dst region if blitting pixels outside read framebuffer on Linux AMD: 664740
Applied Workarounds: adjust_src_dst_region_for_blitframebuffer
AMD drivers in Linux require invariant qualifier to match between vertex and fragment shaders: 659326, 639760
Applied Workarounds: remove_invariant_and_centroid_for_essl3, dont_remove_invariant_for_fragment_input
Disable KHR_blend_equation_advanced until cc shaders are updated: 661715
Applied Workarounds: disable(GL_KHR_blend_equation_advanced), disable(GL_KHR_blend_equation_advanced_coherent)
Decode and Encode before generateMipmap for srgb format textures on Linux AMD: 634519
Software to Accelerated canvas update breaks Linux AMD: 710029
Applied Workarounds: disable_software_to_accelerated_canvas_upgrade
Force integer or srgb cube map texture complete on Linux AMD: 712117
Applied Workarounds: force_int_or_srgb_cube_texture_complete
Accelerated rasterization has been disabled, either via blacklist, about:flags or the command line.
Disabled Features: rasterization
Native GpuMemoryBuffers have been disabled, either via about:flags or command line.
Disabled Features: native_gpu_memory_buffers
Checker-imaging has been disabled via finch trial or the command line.
Disabled Features: checker_imaging
Version Information
Data exported 12/20/2017, 11:26:54 AM
Chrome version Chrome/62.0.3202.89
Operating system Linux 4.10.5-antix.1-486-smp
Software rendering list version 0
Driver bug list version 10.30
ANGLE commit id unknown hash
2D graphics backend Skia/62 e74b4nn6c54638d1a9ee2d254b715bbd9e17c603-
Command Line /usr/lib/chromium/chromium --ppapi-flash-path=/usr/lib/adobe-flashplugin/libpepflashplayer.so --ppapi-flash-version=27.0.0.187 --show-component-extension-options --ignore-gpu-blacklist --no-default-browser-check --disable-pings --media-router=0 --enable-remote-extensions --flag-switches-begin --enable-experimental-canvas-features --disable-lcd-text --num-raster-threads=4 --disable-smooth-scrolling --disable-features=WebRTC-H264WithOpenH264FFmpeg --flag-switches-end
Driver Information
Initialization time 2893
In-process GPU false
Passthrough Command Decoder false
Supports overlays false
Sandboxed true
GPU0 VENDOR = 0x1002, DEVICE= 0x4e50
Optimus false
Optimus false
AMD switchable false
Driver vendor Mesa
Driver version 17.2.5
Driver date
Pixel shader version 1.20
Vertex shader version 1.20
Max. MSAA samples 6
Machine model name
Machine model version
GL_VENDOR X.Org R300 Project
GL_RENDERER ATI RV350
GL_VERSION 2.1 Mesa 17.2.5
Problems Detected
Version Information
Driver Information
Sandboxed true
Optimus false
Optimus false
Driver vendor Mesa
Driver date
Max. MSAA samples 6
Machine model name
Users browsing this forum: No registered users and 80 guests
