I've got a broken G555, with a working screen.
(video chip is bad.)
Will the screen fit a G550, assuming sizes are the same?
There is a G550 on the bay, works but has a bad screen.
steve
G555 screen on a G550?
Re: G555 screen on a G550?
The "standard" difference between such machines is:
G550 has Intel CPU
G555 has AMD CPU
Otherwise they are usually the same.
There is no HMM for G550, but there is one for G555: https://www.manualowl.com/m/Lenovo/G555/Manual/117923
AFAIK both use a 15.6" 16:9 glossy LED-screen (1366×768), almost certainly identical.
Not sure if it's worth spending money on, unless you can get it dirt cheap.
If you get that other machine, you can probably just swap lids.
G550 has Intel CPU
G555 has AMD CPU
T530 Screen Upgrade to FHD Panel - Which Panel?
by Silverlake » Wed Dec 17, 2025 3:39 pm » in ThinkPad T430-T495 / T530-T590 Series - 0 Replies
- 9651 Views
Last post by Silverlake
WTB: T61 14.1" 4:3 screen assembly
by kenzking » Wed Jan 28, 2026 4:30 pm » in Marketplace - Forum Members only - 1 Replies
- 3013 Views
Last post by dcfbf
Wed Jan 28, 2026 5:02 pm
Reduce Contrast on T490 Screen?
by Clueless in Seattle » Fri Feb 06, 2026 1:29 pm » in ThinkPad T430-T495 / T530-T590 Series - 2 Replies
- 3231 Views
Last post by Clueless in Seattle
Thu Feb 19, 2026 2:20 pm
IBM T60 and Lenovo T60, dimmed screen when on battery?
by TP_ » Fri Feb 20, 2026 8:32 am » in ThinkPad T60/T61 Series - 3 Replies
- 4302 Views
Last post by TP_
Sun Feb 22, 2026 1:05 am
