Cannot get an OS to install, T500
Streetguru
So when I bought the machine it was running windows 7 just fine, except it had a locked BIOS with no easy fix
So I got a new board, different kind but the CPU was the same as was the rest, it just added a dedicated GPU.
Gone through 2 motherboards now, ebay seller just shipped me the 2nd one, both had the same issues, it will boot to Gparted and it's been running for 30+ minutes so I don't think there's any instability or overheating. I have a fan blowing down on it as well, it's not passing 40C on the heatsinks.
https://i.imgur.com/nleOgoY.jpg
But trying to install Windows 7 Windows 10, or Even getting Linux Mint to run live fails, 7 crashes and the other 2 make the machine turned off
Tried 2 different AC adapters and nothing, I know the rest of the components work as they were working before, so the motherboard seems to be the issue.
Anyone have any suggestions? Would just be nice if I could get it working, only losing like $80 total if it's not working, Thanks for any help.
Side Note does anyone make a simple Thinkpad Keyboard to USB adapter? I know it needs external processing, but still.
Re: Cannot get an OS to install, T500
Bad CPU comes to mind...
Streetguru
At this point I won't rule it out, but it was 100% running windows 7 booted, working fine as far I could tell before I tried to replace the board.
8ad HDD / SSD perhaps?
sent from my iPhone
hwattys
Bad RAM? Nothing tests memory like installing an OS. Try memtest86
Streetguru
Swapped between a few kits of RAM, it was originally running perfectly fine under windows 7
Had an OS previously installed on the SSD
I have a new CPU installed and it's sitting with Gparted Live running been about 30 minutes again, if It can do that and format the SSD as many times as I want I still don't see why an OS refuses to install, already tried changing my flash drives around and I use them all the time to install OSes.
It just baffles me. Currently it shuts off when I try to install an OS, though I can get farther with my new CPU, at least to the windows install loading screen, didn't get past 10% on extracting files though.
Sounds like an over heating issue. I have a T60 which very easily overheats with windows and freezes or shuts down. Linux runs without issues. Try changing the bios settings; use battery optimized also for AC or something similar setting. Try installing in cooler place. If this helps fix the cooling.
600E (P3-850Mhz), 3*T60 (3*T7200), T400 (8600Mhz/8GB/SSD120GB), T420 (4180-CA3 with Samsung 850 mSATA 250GB), T440p (i7-4702MQ with Samsung 870EVO 1TB)
jaspen-meyer
When you swapped the motherboard, did you also mount the heatsink?
Did you put some thermal paste on the cpu before mounting the heatsink?
A common debugging is to disconnect all periferal devices, dvd, wifi, hdd, one stick of ram, and try booting/installing/etc.
Streetguru
Don't have a heatsink for the new motherboard but I'm checking the small heatsinks I have installed and they're working fine as far as I can tell, not going past 40Cjaspen-meyer wrote: ↑Sun Nov 12, 2017 2:51 amWhen you swapped the motherboard, did you also mount the heatsink?
If it was overheating I don't think it would sit running Gparted foreverRistoE wrote: ↑Sun Nov 12, 2017 1:52 amSounds like an over heating issue. I have a T60 which very easily overheats with windows and freezes or shuts down. Linux runs without issues. Try changing the bios settings; use battery optimized also for AC or something similar setting. Try installing in cooler place. If this helps fix the cooling.
Got a new CPU, still can't install an OS, going to try with the hard drive it came with I suppose, but I doubt it's the SSD.
T410 cannot boot when assembled.
by phinktad » Sat Nov 29, 2025 11:50 pm » in ThinkPad T400/T410/T420 and T500/T510/T520 Series - 3 Replies
- 9172 Views
Mon Dec 01, 2025 2:57 am
T500 Display Problem
by JC8686 » Sat Feb 28, 2026 4:11 pm » in ThinkPad T400/T410/T420 and T500/T510/T520 Series - 7 Replies
- 3799 Views
Last post by deickos
Mon Mar 23, 2026 12:36 am
Get a dual heatpipe mod for your t480, trust me
by swordslasher » Tue Dec 16, 2025 8:43 am » in ThinkPad T430-T495 / T530-T590 Series - 3 Replies
- 10661 Views
Wed Jan 28, 2026 3:06 am
Is it possible to get UDMA on a 760LD with Win98 SE ?
by aka_mgr » Sat Mar 14, 2026 4:56 pm » in ThinkPad Legacy Hardware - 1 Replies
- 1195 Views
Sun Mar 15, 2026 2:56 am
Users browsing this forum: No registered users and 55 guests
