Samsung SSD for T500
Still bringing my newer T500 up to speed.
Today I ordered another Samsung EVO 850 250GB SSD. Along with the new T9600 I installed last week I should see a bit more improvement over the spinner drive.
A31p P-IV 2Ghz, 2MB, 2653-R6U
T500 T9600 2055-BE9
T510 i5 4384-DV7
T510 i7 4349-A64
T16 i7 1260P 21BV000SUS
T500 T9600 2055-BE9
T510 i5 4384-DV7
T510 i7 4349-A64
Re: Samsung SSD for T500
This is an incredible performance increase. Even more noteworthy than installing one of these drives in my T520.
The T500 booted in 43 seconds even with having to scan a fingerprint.
I also installed the Turbo Boost memory module, but I can't say if this had any effect on the boot time or not.
This T500 now boots faster than my T520.
That was $80 well spent and I more than doubled my storage space.
T500 T9600 2055-BE9
T510 i5 4384-DV7
T510 i7 4349-A64
T500 T9600 2055-BE9
T510 i5 4384-DV7
T510 i7 4349-A64
I don't use or deploy any laptop without SSD!
thinkpadcollection
Easier to said that, except for many people does not have budget for SSD especially ongoing too high price problem. 3 years ago I purchased EVO 850 250GB for about 90 CDN which is reasonable. But not anymore till price COMES down once again is needed. What more, I'm not happy about M.2 128GB SSD 2242 length prices (can be over 70CDN currently even from ebay, because I might need to upgrade chromebook's paltry 32GB Acer C720 and C740 series.
My suggestion for spinners: Anyone with small budget can had is better performance is 2 platter platform like HGST 1TB 7200rpm 32MB, Toshiba's 2 platters 1TB 5400prm problem is 8MB buffer, and 750GB (the one with "7575" in Hitachi model number), There are few 3 platter platforms 1.5TB Hitachi/HGST 5400rpm, 2TB samsung/seagate 5400 rpm with 32MB buffer aka M9T model, (better throughput due to appox per 667GB platters), finally HGST's newest 7mm PMR 1 platter 2 heads 1TB spinning 5400rpm Z5K1 with 128MB buffer, I wish HGST came out with 2TB 2 platter model running 7200rpm with dual-chip instead of one 16 bit wide 128MB buffer (still 7mm or 9.5mm), HGST did a 7mm model 1TB with 2 platters but runs at 5400rpm still.
WD is either SMR or PMR on newest models and have to be careful not purchasing any SMR WD models as I noted about Seagate's SMR thing shortly.
Avoid Seagate 7mm 2TB model and spin slowly even at 5400rpm, they are based on SMR which is destructive read & write during writes to rebuild bands of shingled recording just to write small bytes or large bytes. Very inefficient and had Seagate 7mm 2TB model, talk about slow even tried that drive on a C2D computer, can feel the slowness.
Cheers, thinkpadcollection
Yes unfortunately this formfactor seems to be ignored by the tier-1 manufacturers so the few companies that do make them can charge a lot more (and the smaller drives tend to be more expensive per GB too).thinkpadcollection wrote: ↑Wed Dec 06, 2017 2:18 pmWhat more, I'm not happy about M.2 128GB SSD 2242 length prices
Current Thinkpads:
X31, X40, X61T, X61, X201, X220 (i7 IPS), W520 (FHD), T440p (FHD),
T480 (QHD)
Dells: Latitude C840, Precision M70, Precision M4400, M6400 (WUXGA), M6600, M6700, 7730, XPS 13
Daily driver: MS Surface Pro 7 (i7)
T480 (QHD)
It's true that SSDs can still be expensive, but on the plus side: the performance has gotten so darn good over the last several years that even if you're getting a third-hand one from 2012, you're still going to be miles ahead of spinning rust, particularly when it comes to access times and random IOPS. I was an SSD early adopter with the Intel X25M way back when, and the amazing thing was that even the cheapest of the budget drives surpassed it within just a few short years!Easier to said that, except for many people does not have budget for SSD especially ongoing too high price problem.
In my experience, what you miss out on most when you go with an older drive is power efficiency. Each generation of SSD delivers better performance with less energy. Still, it's not usually a huge difference (especially if you're doing a lot of IO.)
Need help with Linux or FreeBSD? PM or catch me on IRC: I'm ThinkRob on FreeNode and EFnet.
Laptop: X270, running Fedora
Desktop: Intellistation 285 (currently dead)
Workstation: owned by my employer
Toy: Miata!
Toy: Miata!
One thing that is to be aware of (and has in fact been discussed before) is SSD sudden death syndrome. Having experienced it first hand about a month ago, I can attest that it's annoying. One day everything works, the next day it doesn't boot, and won't even read anything from the drive. DMA errors all over the place - all the data is completely inaccessible.
The drive was 7 years old, but I have had a few friends and colleagues report similar sudden failures of drives <1 year old...
With spinners, at least 9 out of 10 times there are early signs of impending failure (reallocated sector count increasing in SMART; bad sectors destroying specific files, but rarely a significant portion of the overall data). Plenty of time to backup and replace. Conclusion: if you use an SSD, be even more proactive with backups!
WOW, many thanks for your tip!
We've had our fair share of failing HDD's, but for SSD's we got lucky, our T42 (PATA) SSD failure a few years back did not induce any data loss...
dr_st wrote: ↑Mon Dec 11, 2017 2:40 amOne thing that is to be aware of (and has in fact been discussed before) is SSD sudden death syndrome. Having experienced it first hand about a month ago, I can attest that it's annoying. One day everything works, the next day it doesn't boot, and won't even read anything from the drive. DMA errors all over the place - all the data is completely inaccessible.
I have a fleet of 51 machines at work (98% Thinkpads) all with SSD and haven't had one die yet. I stick to Samsung, Intel, and Crucial for brands. I also stick to MLC only. But yeah always back up to another drive regardless of the drive type. You can't rely on any single drive.
Actually i did get one thinkpad off ebay that came with some no-name brand SSD which ended up being a flakey pos.
You can have SSD for pretty reasonable cost. The amount of time that's saved by SSD more than makes up the cost.
T500 Display Problem
by JC8686 » Sat Feb 28, 2026 4:11 pm » in ThinkPad T400/T410/T420 and T500/T510/T520 Series - 7 Replies
- 3780 Views
Last post by deickos
Mon Mar 23, 2026 12:36 am
Can I restore T14 Gen2 after reset using backup of SSD?
by Thinkpad2024 » Sat Nov 01, 2025 9:33 pm » in Thinkpad T14/T15/T16 - 4 Replies
- 9332 Views
Sun Nov 02, 2025 2:30 pm
Upgrade SSD & RAM on New ThinkPad While Keeping Warranty – Who Tried It?
by marcusfrank » Wed Nov 26, 2025 8:24 pm » in Thinkpad - General HARDWARE/SOFTWARE questions - 3 Replies
- 13852 Views
Fri Nov 28, 2025 4:18 am
P15 gen1 ... will a 1TB + 4TB NVMe SSD pairing work?
by portsample » Thu Nov 27, 2025 8:23 pm » in ThinkPad P1/P14/P15/P16/P40/P50/P70 and later Series - 2 Replies
- 7795 Views
Last post by portsample
Thu Nov 27, 2025 10:00 pm
Users browsing this forum: No registered users and 40 guests
