reflashed a driver on my x220 to fix pointe/non-oem charger issue. trackpad and pointer are dead, can't get them back!
RoamingAndy
Here's the driver i flashed from the Lenovo site: https://forums.lenovo.com/t5/tkb/articl ... cle-id/352
( PR1063847-tm1611.img )
i'm not being lazy by reaching out. i've been trying to fix it for 7hrs now. i've reverted to a previous restore point and nothing.
tried older drivers, including some not for the x220 but a few users in forums found they worked. uninstalled and reinstalled ultranav. checked bios settings. been through every suggestion in support forums. and yes, i've pressed fn + f8 to turn it on
something about that reflash file has completely messed up my laptop, and i'm out of ideas other than a complete wipe and reinstall of windows 7, which i'd like to avoid. (running win 7)
can anyone help?
can anyone help?
Re: reflashed a driver on my x220 to fix pointe/non-oem charger issue. trackpad and pointer are dead, can't get them bac
Try opening up the laptop and disconnecting the touchpad's cable. If the trackpoint works, then it could mean that the touchpad got bricked.
RoamingAndy
thanks, i tried that and have the trackball and buttons back. is there any solution to recover a bricked trackpad?
Either replace the complete palmrest or try and swap out the flat cable between touchpad/FPR and motherboard with a known good one.
Sometimes there's simply a tiny bit of corrosion or dust preventing a device to run normally. That gets resolved by reseating a plug. Plug the touchpad back in, maybe it works normally again. Had that issue with my T61. And a similar issue on my sister's SL510.
X62s 3rd batch, X210Ai 1st batch, ex. [s]T61[/s] T70 14" 4:3 1st batch
Enabling trackpad cannibalizes the trackpoint
by dcfbf » Tue Nov 25, 2025 4:59 pm » in ThinkPad T60/T61 Series - 3 Replies
- 8487 Views
Last post by dcfbf
Thu Nov 27, 2025 8:51 pm
Has anyone modified the hinge/springs in a trackpad?
by jonzilla5000 » Tue Jan 06, 2026 6:28 pm » in Thinkpad T14/T15/T16 - 0 Replies
- 4792 Views
Last post by jonzilla5000
Trackpad unusable with Ubuntu (Unity) 24 LTS
by gdeangel » Sat Feb 21, 2026 8:37 pm » in Linux Questions - 1 Replies
- 2560 Views
Last post by farmall
Thu Mar 26, 2026 11:42 am
My ThinkPad fleet and my shiny-plastics-fix hack
by lukee » Fri Jan 23, 2026 3:34 am » in Pictures of your ThinkPad & desk setup - 6 Replies
- 6049 Views
Last post by David C
Wed Feb 11, 2026 9:55 pm
