SSD For X1C 6th Gen
u751920
SSD For X1C 6th Gen
#1 Post by u751920 » Sun Feb 24, 2019 7:04 pm
Hello All,
Does anyone know off hand which SSD will work/fit the 6th Gen X1C? I'm looking to buy a 1tb samsung SSD.
X301 SU9600 1.6Ghz 256SSD 8Gb RAM WWAN&GPS BT Windows 7 Pro 64bit Batteries 6 Cell & Bay
w0qj
Re: SSD For X1C 6th Gen
#2 Post by w0qj » Mon Feb 25, 2019 8:15 pm
Howdy!
I believe any M.2 PCIe NVMe SSD would work on your X1C6 (6th Gen), which should be of the 2280 form factor (ie: 22mm X 80mm).
Something like this one:
[Disclaimer: I'm a fellow ThinkPad user; I do not work for Samsung!]
www.samsung.com/sg/memory-storage/970-p ... Z-V7P1T0BW
Actually, above advice would work for any ThinkPad X1C4 (X1 Carbon 4th Generation) and onwards, which all work with this M.2 PCIe NVMe "2280" SSD.
The same goes for X1 Extreme and P1.
u751920
#3 Post by u751920 » Tue Feb 26, 2019 3:40 pm
Thanks for confirming that.
