ThinkPad T480s QHD to UHD 4K LCD screen Upgrade LP140UD1-SPD3
iamdmc
Photos here: https://imgur.com/a/FYEvdAm
Following on from my FHD (1920x1080) to QHD (2560x1440) panel upgrade from late 2018, I decided to take the jump to UHD (3840x2160). Here's my guide on replacing the panel: https://old.reddit.com/r/thinkpad/comme ... pplies_to/ note you will absolutely need the QHD+ 40 pin eDP cable for this mod if you're going from FHD to QHD or UHD. If you already have a QHD screen then all you need to do is unplug the old panel and pop the new one in
**PANEL PROGRESSION**
First panel from factory was a terrible BOE NV140FHM-N46, 1920x1080, 6-bit color (252K colors, 68% sRGB, 38% adobeRGB), dim 220cd/m2, with noticeable 'IPS glow'
Second panel from FHD to QHD upgrade was a decent AUO B140QAN02.3 (not the better B140QAN02.0 that supported HDR and 500cd/m2). 2560x1440, 8-bit color (16.7mil colors, 100% sRGB, 60% adobeRGB), a bit brighter at 300cd/m2, and no noticeable 'IPS glow'
Current panel from QHD to UHD upgrade is an LG LP140UD1-SPD3: 3840x2160, 8-bit color (16.7mil colors, 100% sRGB, 100% adobeRGB, 100% DCI-P3), a step brighter at 350cd/m2, and no noticeable 'IPS glow'
**Some details about the upgrade**
Before you start, I agree with you: 1440p (220PPI) is good enough for most everything... but I do work with details that I sit nearer to my screen and 1440p loses its 'retina' quality nearer 16", whereas 2160p (315PPI) is good up to 11" and that's about as close as I'll ever sit to my screen.
Other notable improvements from this upgrade are a noticeable jump in peak brightness, ever so slightly crisper text, and sharper video. The color reproduction is also far better. The jump from QHD to UHD wasn't as massive as the jump from FHD to QHD (possible because the Lenovo factory installed FHD panel was inexcusably bad).
Of note, the initial color reproduction was terrible, contrast and white balance were way off, and it absolutely required a calibration. You can use ICM files from the web, but it's always better to calibrate your own individual panel. I picked up a calibration tool (X-Rite i1Display Studio) for 87GBP on amazon, and have used it on my LG 4K projector, LG 4K 27" monitor, several 14" laptop panels, and a few external portable monitors. Calibration sometimes doesn't change much, but in this case it made a huge difference. If you get this panel and need an ICM file message me and I can email you mine with the caveat that 'your mileage may vary'
**Where can I get one**
I sourced the panel from [this seller](https://www.aliexpress.com/item/1005003 ... 4c4dI4TGNb) aliexpress for about 87GBP taxed & delivered. Pro tip: ask each seller you're considering to send you photos and videos of the panel - the best sellers will and are also very responsive to messages. No it wasn't new, but no panels on aliexpress are. I paid around the same price in 2018 for my QHD panel from a UK seller, and it was a new screen in a Lenovo box (so the EDID populated correctly whereas it does not on the new panel), but again that was QHD. The LG UHD panel is, unfortunately, thicker and wider than even the original FHD panel so some lid modification was required and my trusted dremel came out to play. You basically need to grind down all of the raised plastic tabs on the inside lid and under the plastic bezel/frame to fit in the new panel - this took a bit of time. It's not a drop in replacement as the QHD panel was or some other UHD panels, but compared to the other options out there from the likes of BOE which are reviewed as grainy and not as color accurate, the LG panel was worth the effort. I don't recommend this upgrade for the feint hearted.
Any questions feel free to ask!
ThinkPad X1C gen10 (2023)
i5-1235U | 16GB RAM | 2TB Samsung 990 Pro | QHD OLED
The X61 is dead... long live the X61
Past * current IBM (&lenovo) ThinkPads: X1C12, X1C10 P14s gen2, T480s, T450s, X250, X230, X220, X300, T410, X61s, T60p, T41, X31, T23, A21m
Re: ThinkPad T480s QHD to UHD 4K LCD screen Upgrade LP140UD1-SPD3
Hello and thank you for the detailed pictures and work on this. I love my T480s but as its my main working machine I suffer from the poor FHD screen. My use of the laptop is programming and system development but I take my laptop everywhere and need it to be useable also in places with sunlight or a lot of natural light. I dont really care about color accuracy or movies or anything like that. What i really need is high resolution to comfortably be able to show more detail without straining my eyes and more brightness to work comfortably in varying light conditions.
From your work I gather that the UHK screen is good but it looks like a daunting prospect to mod the screen case so much. I think I would be best to go with the high brightness QWHD screen you mention (B140QAN02.0). Am I right in thinking that this is the best mod for my use? I have found what looks to be a reputable seller on Aliexpress for this screen (https://www.aliexpress.com/item/4000911 ... 9600%22%7D) and I have asked the seller to give me information about the screen on hand and with pictures.
I have read elsewhere that there are a few low-power FHD screens with really high bightness as well (the models are not at hand) but I think the combo of both high bightness and the extra resolution will add a lot to my trusted T480s.
Only question is if the screen is glossy or matte (hoping it is) and that it does not draw all the battery out of my laptop (which is not the end of the world).
Thanks again for sharing all this - soon - hopefully - I will be trying out the mod myself.
cheers
Lars
cheers
Lars
iamdmc
Hi Lars
You're correct that the QHD screen model you mentioned is best for your use case, but it is also glossy (as are most 500nit + HDR displays, sadly). There are supposedly UHD 500 nit matte panels in the T14 gen 2 that would also meet your needs, but may not be drop in replacements as the QHD panel is, and I haven't even found those new panel models (2021 production) on any consumer facing marketplace yet. When they do become available (likely mid 2022 thanks to the ongoing shortages) they will likely cost 2-3x what the QHD panel does.
Read some panel reviews (especially the excellent review by notebookcheck) and decide if it's right for you. Best of luck!
iamdmc
Ps I wouldn't trust that you're getting the B140qan02.0 as this seller has multiple model numbers from different manufacturers listed
Thank you so much for this. I have found a seller that has shown me the original panel and all for the B140QAN02.0 - so I think I will go for that. And if it is too glossy i will experiment with applying a matte film over. If it really does not work for me I can resell it i figure. It seems to be the best option. Will post my experience here when I have done this. Thanks again.
iamdmc
from personal experience, it's incredibly hard to resell a panel. Buy with the intention of keeping, and consider that if you can resell it you'll probably lose half of the value you paid
Right so I actually reconsidered - I went for the WQHD panel that is matte LP140QH2-SPB1, it is not as bright as the HDR panel but it is not glossy and that would really defeat the purpose. After reading the review on notebookcheck it was really evident to me that I would not like the glossy panel for my tasks (programming/development in varying light conditions on the go). So now waiting for the panel as it arrives in a few weeks. Looking forward to is. And yes I have bought to keep.
iamdmc
You'll be happy with that panel I'm surelsp1138 wrote: ↑Sun Oct 31, 2021 5:21 pmRight so I actually reconsidered - I went for the WQHD panel that is matte LP140QH2-SPB1, it is not as bright as the HDR panel but it is not glossy and that would really defeat the purpose. After reading the review on notebookcheck it was really evident to me that I would not like the glossy panel for my tasks (programming/development in varying light conditions on the go). So now waiting for the panel as it arrives in a few weeks. Looking forward to is. And yes I have bought to keep.
Possible Upgrades for a T480s ?
by MortacioRatio » Sun Nov 16, 2025 8:24 pm » in ThinkPad T430-T495 / T530-T590 Series - 1 Replies
- 5727 Views
Mon Nov 17, 2025 1:18 pm
PCIe5 SSD in T480s
by dandreye » Wed Feb 11, 2026 7:39 pm » in ThinkPad T430-T495 / T530-T590 Series - 2 Replies
- 1621 Views
Last post by dandreye
Thu Feb 12, 2026 4:49 am
T480s with SATA SSD?
by dandreye » Thu Mar 12, 2026 6:09 am » in ThinkPad T430-T495 / T530-T590 Series - 2 Replies
- 1187 Views
Thu Mar 12, 2026 11:42 am
- 5 Replies
- 10568 Views
Last post by Python.p
Mon Oct 27, 2025 3:57 am
Users browsing this forum: No registered users and 137 guests
