T15 gen 2 won't turn on - blinking lights - dead mobo?
iamdmc
After not using my T15 gen 2 for a few weeks I finally tried to turn it back on. I tried plugging in the laptop in case it was a dead battery, but even after a few hours on charge it did not power on. I've tried the 'reset' button on the bottom of the laptop (with and without the battery and CMOS battery connected) to no avail. I've tried removing and re-seating memory, SSDs, etc. No peripherals plugged in.
Strangely, it did turn on once when I swapped in a T14 gen 2 battery (to test if the battery was faulty) but after shutting down again it didn't turn on again.
Behaviour 1:
When I plug in the charger, I get blinking lights (on/off every 1-2 seconds) on the lid (the i), the power button, and the LED next to the USB C charging plug. It's not the same blinking behaviour as 'sleep' and the T15 remains unresponsive to power button presses.
Behaviour 2:
Sometimes, I can press the power button and get the fan to ramp up, followed by 3 flashes from the power button LED, then the laptop turns off again. Press the power button again - same thing happens
either way NO BOOT - no beeps, nothing
I can't for the life of me understand what it could be... bad motherboard maybe?
Has anyone had any similar experience or have any idea what this could be?
Behaviour 1:
Behaviour 2:
ThinkPad X1C gen10 (2023)
i5-1235U | 16GB RAM | 2TB Samsung 990 Pro | QHD OLED
The X61 is dead... long live the X61
Past * current IBM (&lenovo) ThinkPads: X1C12, X1C10 P14s gen2, T480s, T450s, X250, X230, X220, X300, T410, X61s, T60p, T41, X31, T23, A21m
Re: T15 gen 2 won't turn on - blinking lights - dead mobo?
Bad power supply?
Bad USB C port?
Bad USB C port?
iamdmc
Thanks for your reply
I've tried several Lenovo usb c 65W chargers on several plugs around my house and no difference
Either usb c port seems to charge the battery, as it reads as 100% when plugged into my other laptop. If anything I don't think it's the charge circuit
Open it up, disconnect the battery, hit the power button for a few seconds, and re-attach the battery. That should drain the capacitors and reset the system. If it doesn't power on after that, send it to warranty.
Also, my X1C4 has a small hole in the base to reset the BIOS to factory defaults. Does the T15 Gen 2 have that?
iamdmc
Thanks for the reply. I jiggered it just right (no idea how) that it started working againmikemex wrote: ↑Fri Mar 04, 2022 11:40 pmOpen it up, disconnect the battery, hit the power button for a few seconds, and re-attach the battery. That should drain the capacitors and reset the system. If it doesn't power on after that, send it to warranty.
- 1 Replies
- 4857 Views
Last post by ogopogo
Thu Feb 12, 2026 5:07 pm
Thinkpad T60 won't turn on
by cynthiacarmichael » Thu Mar 26, 2026 4:40 am » in ThinkPad T60/T61 Series - 1 Replies
- 645 Views
Last post by Glaurung-quena
Thu Mar 26, 2026 9:34 am
X1 tablet gen 3 won't boot after SSD replacement
by babblefish » Thu Feb 19, 2026 10:22 pm » in ThinkPad X1 / X1-Carbon / X1-Extreme and later Series - 7 Replies
- 3683 Views
Last post by babblefish
Fri Feb 20, 2026 7:44 am
X61s screen backlight doesn't work. Faulty mobo?
by huohuo » Tue Mar 03, 2026 6:35 pm » in Thinkpad X60/X61 Series incl. Tablets - 4 Replies
- 2565 Views
Last post by huohuo
Sat Apr 04, 2026 3:43 pm
