Convert 14” Keyboard to 15”?
Plunkyy
Looking at replacement keyboards since my newest 15” T42 came with an awfully mushy chicony keyboard. Seems quite a bit cheaper to buy 14” Keyboards than any listing that specifically sells 15” ones. Wondering if anyone has ever just dremeled off the 4th standoff to make it a DIY 15” model? Would this damage the keyboard some how? Would love to hear any thoughts on this.
600X: 650Mhz Speedstep
Gonzaleitor
Re: Convert 14” Keyboard to 15”?
I did it, You have to cut one of the stand offs (I don't remember wich one right now), it's pretty simple. If You do it carefully there shouldn't be any damage, just check wich one is the one in the way and cut it.
Plunkyy
Oh ok awesome, I figured it should be fine I've just never heard of anyone doing it so I wanted to make sure I wasn't missing anything. ThanksGonzaleitor wrote: ↑Fri May 16, 2025 9:21 amI did it, You have to cut one of the stand offs (I don't remember wich one right now), it's pretty simple. If You do it carefully there shouldn't be any damage, just check wich one is the one in the way and cut it.
Gonzaleitor
No problemo. I had the same problem as you and thought "what the hell?" and cut It. It worked.
Glaurung-quena
OK, I am confused. I have both a 14" and a 15" keyboard. Held them up side by side and none of the posts under the mouse buttons at the bottom line up. You'd have to remove at least two posts at the bottom and not have it secured at the bottom at all to fit a 14" KB into a 15" case.
It's hard to tell but I think the post near the centre of the keyboard is also not in the same place. The only post I am sure is the same between the two is the one in the upper corner.
Gonzaleitor
Yeah, it's something like that.Glaurung-quena wrote: ↑Sun Jul 06, 2025 8:42 pmOK, I am confused. I have both a 14" and a 15" keyboard. Held them up side by side and none of the posts under the mouse buttons at the bottom line up. You'd have to remove at least two posts at the bottom and not have it secured at the bottom at all to fit a 14" KB into a 15" case.
Plunkyy
Just logged on to update after I attempted it and now I see your post lol… I dremmeled off the extra screwpost on a 14” ALPS keyboard and tried to install it. EVERY screwpost is offset to the left compared to the 15” NMB I have. So this mod just isn’t possible if I want to have even one screwpost holding the keyboard inGlaurung-quena wrote: ↑Sun Jul 06, 2025 8:42 pmOK, I am confused. I have both a 14" and a 15" keyboard. Held them up side by side and none of the posts under the mouse buttons at the bottom line up. You'd have to remove at least two posts at the bottom and not have it secured at the bottom at all to fit a 14" KB into a 15" case.
Maybe it’s different in 14” chicony/nmb, not sure as I don’t have any.
Glaurung-quena
It will be the same on every type, since all the keyboards for each screen size are interchangable.Plunkyy wrote: ↑Mon Jul 14, 2025 10:12 amJust logged on to update after I attempted it and now I see your post lol… I dremmeled off the extra screwpost on a 14” ALPS keyboard and tried to install it. EVERY screwpost is offset to the left compared to the 15” NMB I have. So this mod just isn’t possible if I want to have even one screwpost holding the keyboard in![]()
I have a a spare 15" T4x keyboard, but sadly two keycaps have come off (page up and delete, IIRC) and my attempts to install new ones went poorly (all thumbs, aging eyes, and tiny little plastic parts don't mix). DM me if you want me to mail it to you.
Plunkyy
Yea I guess you’re right about all 3 keyboards being the same… oh well. Thanks for the offer but I do have a decent 15” NMB already, I just wanted to switch it out for the 14” ALPS keyboard I have since I think I actually prefer those better on T4x. They’ve got kinda NMB-style platform switches and are nice and clicky. I’ve got a friend with a 15” ALPS as well that I think I will trade him my 15” NMB for, win-win
- 13260 Views
Last post by Scorpion8
Wed Nov 19, 2025 4:42 pm
WTB: T60/T60p 15” palm rest and keyboard bezel
by stanleylieber » Fri Oct 31, 2025 4:32 pm » in Marketplace - Forum Members only - 3 Replies
- 6345 Views
Last post by KAQSP
Thu Nov 20, 2025 6:33 pm
ThinkPad T25 ANSI US Keyboard from Amazon
by vermaden » Sun Nov 09, 2025 6:26 pm » in Thinkpad T25 Anniversary/Retro - 1 Replies
- 8210 Views
Last post by David C
Tue Jan 27, 2026 9:30 pm
X200T - no boot with keyboard plugged in - help.
by GloomySugar » Mon Nov 17, 2025 5:11 am » in ThinkPad X200/X201/X220 and X300/X301 Series - 0 Replies
- 5448 Views
Last post by GloomySugar
Users browsing this forum: No registered users and 54 guests
