First steps after buying a used Thinkpad
Want to know HOW TO..? Have a FREQUENTLY ASKED QUESTION..?
If you can't find it here, tell us and we'll publish whatever you need
Thinkpad2024
#1 Post by Thinkpad2024 » Tue Nov 18, 2025 3:55 pm
I've just ordered a used X1 Extreme Gen 2 to have as a backup. Aside from making sure it has all the updates, is there anything else I should do upon receiving it, before I start using it? Should I wipe and reinstall the OS for security reasons?
dcfbf
Re: First steps after buying a used Thinkpad
#2 Post by dcfbf » Tue Nov 18, 2025 5:30 pm
First thing I do is to test if everything on it works.
I open up static colors to make sure that there's no dead pixels or backlight bleed.
I try out all the ports and all the keys on the keyboard
After that, I change the thermal paste and clean it.
Make sure to clean it. You do not know what the previous owner did with it.
Aside from that, I upgrade with whatever I have on hand and yes run all the updates.
If there's a bios mod for the machine, I usually also install that.
I don't see any reason to reinstall the OS if it's fresh and there's no accounts on it.
Current Dailies: X1C6, P71
Thinkpad2024
#3 Post by Thinkpad2024 » Tue Nov 18, 2025 6:15 pm
Thanks. How do you "open up static colors"?
dcfbf
#4 Post by dcfbf » Tue Nov 18, 2025 8:26 pm
When you boot the system up, press F10 to get into Lenovo diagnostics
You can also reach Lenovo diagnostics by pressing enter to get into the startup interrupt menu and then pressing F10
From there, you can do the display test which will show you static colors and other patterns to test for the display
Edit: This only works for Thinkpads newer than 2012. If you get a ThinkPad that's older or if you don't want to be poking around in diagnostics, you can use https://www.eizo.be/monitor-test/.
Return to “** HOW TOs & FAQs **”
