Thinkpad T460s and Linux Ubuntu
I have not used this machine much in the last few years and today installed Ubuntu onto it, keeping the Windows core. If I remove Windows completely, will there be any problems associated with hardware or anything else? I would rather just have Ubuntu on it and not worry about Windows updates (that have ended anyway) etc.
dcfbf
Re: Thinkpad T460s and Linux Ubuntu
Nope. You don't have to worry. Just make sure you have all your personal files backed up.
ThinkPads play quite well with Linux and the only thing I know of that is on Windows and not on Linux is Lenovo software.
Those are covered by built in Linux packages though so you don't need to worry.
Though actually you may want to check fprintd supports your fingerprint reader if you have it and want to use it.
Current Dailies: X1C6, P71
The T460s is old enough to have great support on Linux. The only possible wrinkles I could think of are the Geforce 930M GPU (if your T460s has it) and the fingerprint reader.
It is just Intel graphics, not a discrete card.
The fingerprint reader is a Validity Sensor VFS7500. I have tried a procedure for installing it, but it did not work. But it is not critical to have it functioning.
T470s won't allow me to login into Linux -- only UEFI, boot screens and tty interfaces seem to work
by irock » Wed Mar 18, 2026 3:34 pm » in ThinkPad T430-T495 / T530-T590 Series - 4 Replies
- 2350 Views
Last post by farmall
Fri Mar 27, 2026 2:26 pm
NetSurf 3.11 compilation for classic Ubuntu
by lukee » Wed Jan 21, 2026 5:45 am » in Linux Questions - 1 Replies
- 3716 Views
Thu Mar 26, 2026 11:56 am
Trackpad unusable with Ubuntu (Unity) 24 LTS
by gdeangel » Sat Feb 21, 2026 8:37 pm » in Linux Questions - 1 Replies
- 2437 Views
Thu Mar 26, 2026 11:42 am
Thinkpad t420 Linux Mint boot settings
by mannyrd12 » Sun Mar 22, 2026 11:25 am » in ThinkPad T400/T410/T420 and T500/T510/T520 Series - 7 Replies
- 2180 Views
Fri Mar 27, 2026 2:03 pm
Users browsing this forum: No registered users and 65 guests
