T500 Display Problem
JC8686
#1 Post by JC8686 » Sat Feb 28, 2026 4:11 pm
I recently upgraded the display on my T500 from the 1280x800 panel to the 1680x1050 panel however when i installed the display and booted the machine the backlight stopped working but I could make out the faint lenovo logo. When I went to reseat the ribbon cable and inverter it stopped displaying an image and the status LEDS also stopped working and when I connected to an externel monitor it only recognised the monitor.
I have tried two different ribbon cables and two inverters however they all produce the result above. I know that this could be an issue with the fuses being blown however I dont think this happened as the battery was disconncted during the process and there was no flash from to the screen to indicate a blown fuse. It is also not an issue with the panel as I swapped back in the old display but it produced the same problem.
I am creating this posts to see if anyone has a solution or has encountered the same problem and would be able to share their thoughts as to how they resolved the issue. :)
Re: T500 Display Problem
#2 Post by RealBlackStuff » Sun Mar 01, 2026 2:30 am
Maybe you changed from a CCFL screen to a LED screen.
In that case you also need to change from an inverter card to a LED control card.
See the HMM for details/part numbers.
JC8686
#3 Post by JC8686 » Sun Mar 01, 2026 10:17 am
I'm not sure I dont think that is the case as they only made the 1280x800 in LED and mine was not.
#4 Post by RealBlackStuff » Sun Mar 01, 2026 11:18 am
Your reply makes no sense...
TPFanatic
#5 Post by TPFanatic » Sun Mar 01, 2026 2:28 pm
In my opinion it seems most likely something on the board failed, could be fuses. Fuses are replaceable. I agree it should not have happened because power was disconnected, I have no belief against your due diligence. I blew up a T540p once even tho the power was disconnected, the caps were still charged, I thought I’d drained them but I guess not
Things happen, unfortunately.
JC8686
#6 Post by JC8686 » Tue Mar 03, 2026 4:05 pm
Tested the fuses with a multimeter today and they seem all good. I'm just going to order a new inverter board and hope for the best.
teamde78
#7 Post by teamde78 » Sun Mar 15, 2026 8:48 pm
Yes agreed, I would try a new inverter board.
Thinkpads: X1 Yoga Gen 5, X1C 5th Gen, T430s
deickos
#8 Post by deickos » Mon Mar 23, 2026 12:36 am
yea agree - a fatal flaw in the T400 model occurs when the lcd cable shorts and blows the fuses beside the lcd socket on the mb... maybe this is also the case here
this t400 fatal flaw is very common as i learned
T500 - T9600, 8g ram, 1680x1050
T420 - 2450M, 16g ram, 1366x768
X61t - L7500, 4g ram, 1024x768
W520 - 2760QM, 16g ram, 1920x1080
X201 - 560M, 8g ram, 1280x800
Users browsing this forum: No registered users and 271 guests
