755c PCMCIA Cover
solidpro
755c PCMCIA Cover
#1 Post by solidpro » Wed Apr 08, 2026 6:43 am
I made one. It's more basic but fits and does the job perfectly. It's different to the one in the 760.
Image Image Image
It's here:https://ret.rocks/files/755c-pcmcia-cover-mk3.stl.
panips
Re: 755c PCMCIA Cover
#2 Post by panips » Wed Apr 08, 2026 6:15 pm
The side profile of the ThinkPad 75x/76x is not perfectly vertical; it has a tapered design (wider at the top and narrower at the bottom). To achieve a flush fit, you may need to set the angle between the faceplate and the latching rails to 85 degrees (a 5-degree offset from perpendicular)
I shared a 3d model before, and here is the TinkerCAD link
https://www.tinkercad.com/things/d7VnH0 ... 7x80RXEUU8
75x and 76x are slightly different but it's easy to remix based on this one.
:cry: 510cs, 555bj, 860, Type 2435
WTB: 300C, 320, 700T, 710T
solidpro
#3 Post by solidpro » Thu Apr 09, 2026 12:55 pm
Your one doesn't fit the earlier 755c/755Cs - if you look closely, the 755c one i've shared has two notches which are the first signs it's completely different.... As you may recall the early 755C and 755Cs share more similarities with the 750 than the later 755 range - different insides, no volume control dial, different screens, different PCMCIA covers... and the 750 PCMCIA cover is the same on the 755C.
I'll look at this 85 degree thing, however the one I've made does fit pretty flat and flush. I copied an original and because of it's inserted position, the degree angle of the side of the base would make no difference...
Bondi
#4 Post by Bondi » Sat Apr 11, 2026 2:14 am
Cool! Thanks! Does it fit 360 series? Looks very similar to me.
Thinkpads: 330C, 360CE, 560, 755CD, 760LD, 760EL, A21p, A31p, X60s, X230, X280
solidpro
#5 Post by solidpro » Sat Apr 11, 2026 8:14 am
I looked at the 360 base and it uses the same PCMCIA cover as the later 755s, not the 750/755C/Cs - so use the one provided by @panips and you should be good.
panips
#6 Post by panips » Sat Apr 11, 2026 4:24 pm
I checked and tested the 755c cover, it's in fact 3 degree (tan3' is about 1/19), which is exactly what I have used. So it's easy to create one by adding two notches (holes of trapezoidal platform).
https://www.tinkercad.com/things/57cfz0 ... Z-RroCGZ94
For such a small part, it must be created accurately to fit the original laptop perfectly, that's why I managed to have a 1:1 replication accurate to 0.1mm. BTW: SLA/LCD can get you a perfect replica, but FDM 3d printing would not.
